Ga door naar hoofdinhoud
The 7" Amazon Fire ninth gen model was released on June 6, 2019 and featured 16 GB or 32 GB of storage space.
7 Vragen Bekijk alle
Is there any way to install Qi charging
I have a car setup for using this tablet as a radio head unit but I can’t charge and use the CarPlay adapter at the same time is there a way to add Qi charging function to the fire 7 2019 so can be left fully in situe to allow use and charging in place
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I know in the case of some older apple products before they added wireless charging there were cases available that would plug into the charging port. However I doubt such a product exists for your tablet and to add it would require a lot of work and microsoldering you’d be better off spending the money on a better tablet. So to answer your question, you most likely cannot add Qi charging to your tablet.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Michaela snow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 298
