Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Screen or Logic Board fault?
I have an iPhone 5c that was water damaged. The phone boots to home screen, however the screen does not respond to touch. There is a bit of corrosion on the screen connector. After I clean the corrosion, if the problem persists, is there a way to know if it is just the screen or a board level problem?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Clean the connector. If that doesn’t work, try a different display. If that doesn’t work, then try the original display with a different phone. If that doesn’t work, try factory reset (if you’re willing to)
If all fail, then it’s board-level.
Good luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the help!
door
Voeg je antwoord toe
Caleb Topper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 49
Altijd: 211
