Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
705 Vragen Bekijk alle
My switch doesn’t put anything out to my TV! Any help?
I’ve tried the official Nintendo guide and I’ve tried different HDMI cables. It has to be the chip that controls the TV stuff that’s broken. Anyone have a solution or alternatives so I don’t have to crack my switch open?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi!
.Has there been any water spilt on the switch at all or has it been dropped as these devives are quite flimsy and easily damaged. If nothing is working it could possibly be your dock if you have tried another dock and still nothing then it sounds like it is your p13 chip. That is located on the back of the motherboard the controls HDMI output. Normally replacing this would resolve the issue however it involves soldering skills. You can send it into repair to somewhere local or myself as I have a repair company and deal with these kind of issues
Was dit antwoord nuttig?
3 opmerkingen:
I don’t have another dock, and I got the switch off eBay.
door
Aside from the whole motherboard thing here, is there a guide on how to replace the P13 chip?
door
There is yes you need flux and a hot iron and a microscope to do it
door
Voeg je antwoord toe
Daniel Heim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 50
