Ga door naar hoofdinhoud
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
82 Vragen Bekijk alle
Maytag Bravos XL washer stops mid-cycle, drains, shuts off
Maytag Bravos XL washer, model no. MVWB835DW2, will not complete a wash cycle. Tub fills, wash starts, then after a few minutes, the power light starts blinking and the tub starts draining. Once the tub is empty, the washer shuts off (no lights or error codes). I have already tried resetting it with the same results.
Is dit een goede vraag?
Score 1
1 Opmerking:
I too have the maytag xl top load washer. It keeps leaking alot of detergent from the bottom. What is causing this? It also smells like something burning or im not sure what the smell would be? Can anyone help with this. Its not that old. Purchased at Lowe's along with the dryer.
door
Voeg een opmerking toe
1 Antwoord
From what you are describing, it sounds like you have a shorted keypad in the console. **Most likely** will have to replace the console (simply based on the problem description). Part Number W11112656.
You can check error codes on this unit to be sure by entering diagnostic mode. I use the three buttons to the right of the knob for this. I believe it is Temperature, spin speed, soil level(?).
To do that: With the unit off, start with the top button and press and release each in succession : 1,2,3,1,2,3,1,2,3. You have to do this within 8 seconds. All of the lights on the console will come on, and will show you any error messages that are stored. Error codes appear as F#E#. For example: a fairly common error for the issue you are describing is F6 E3.
This is my best answer without an specific error codes. Good luck!
Was dit antwoord nuttig?
2 opmerkingen:
I tried pushing the 3 buttons 3x in quick succession, nothing happens.
door
@Amanda Anderson
What is the model number of your washer?
door
Voeg je antwoord toe
Matt Maynard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 136
Altijd: 7,274
