iMac shuts down, and restarts randomly
I’ve been having an odd issue with my iMac. It starting having this behavior where it will randomly shut down. Sometimes it’s an hour into using it, other times it’s when it’s booting up. Sometimes, when it chooses to shut down, it chimes and tries to restart several times. Chime - Chime - Chime. Sometimes it fully boots, other times it turns off and requires an SMC reset.
Everything pointed to a bad PSU, so I ordered one from iFixIt. I pulled a LiteOn PSU, and installed the Delta brand PSU from iFixIt. The Delta replacement part was used.
Pretty easy swap, however my issue persists. I thought maybe the PSU I got from iFixIt was bad. Contacted them, and they sent me a replacement. This time it was a LiteOn PSU. I swapped it out, and still have the issue.
Last night, it played a looping movie all night long (never shut off). As soon as I got up this morning, starting opening apps and such, it shut off.
My son plays Fortnite on this iMac. Sometimes he can play it for hours before it shuts down. Sometimes it lasts 10 minutes. Sometimes it won’t even get past the Apple logo on startup.
Things I have tried:
- Using the computer in a different room (different circuit/breaker).
- Swapped the PSU twice
- Tried a new power cord
- Installed new RAM
- Did a clean install of Catalina
- Checked temps during heavy usage (all good)
- Viewed LED lights on logic board (all good)
So what’s the deal? I probably have a bad logic board, right?
Random bits of details:
- I discovered that the surge protector the iMac was plugged into was not grounded. This was before I replaced the PSU. I purchased a new surge protector, then replaced the PSU when that did not alleviate the issue. I have heard that these iMacs are picky about being grounded.
- I have a lot of devices on the same circuit/breaker. I have unplugged everything else (except the iMac) and the issue still persists.
- I have a new iMac in my office that works fine, so I don’t think I’m having a surge issue issue, or some other issue with the quality of electricity coming in.
- I’ve done lots of testing, and I guess I can chock most of it up to “chance.” For example, my son was playing XBOX (same room). When he turned it off, the iMac restarted (it was asleep at the time). When I tried to replicate, it did not happen.
Idling:
During Video Encoding:
Idling after Encoding:
Is dit een goede vraag?
