Ga door naar hoofdinhoud
Reparatiehandleidingen voor de MacBook.
3787 Vragen Bekijk alle
Is there no inverter cable?
I have this Early 2009 Macook 2.0Ghz Core 2 Duo. I bought it with this problem where the backlight goes off at about 45 degrees and comes back on somewhere at the 120degree angle. I tried to look for parts but I cant find any inverter cables. I know these sometimes break internally and it has happened with one of my older ones, which I did replaced. I cant find the same part for this laptop when I researched it on Ifixit. Does this not have the same cable that the older ones had?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes there is an inverter cable for the early 2009 MacBook. It takes the same one that the MacBooks late 2007 Santa Rosa - early 2008 Penryn use ( 3 wall connector on the board). Ifixit does not have any in stock at the moment. Here is a link verifying that the early 2009 MacBook takes the same cable I mentioned. Here is a google shopping search for the part.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Zahan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 790
