I want to erase memory from phone
Is dit een goede vraag?
bahamaina, this will clear ALL YOUR INFORMATION, so only do it if that is what you need to do. The 680 does not have a reset button, so you need to use the battery as reset button:
-Remove the battery,
-Insert the battery, and immediately press and hold the power button.
-Wait till the first time-bar is fully loaded, and the palm logo
shows, if you can't see the screen because it is cracked, just hold
the power button for 1 minute.
-Release the power button,
-The screen says now: erase all data ? (Yes = up, No = other button)
-press the 5-way navigator to the UP position.
-Now the PDA is erasing user data. This will take about 10 seconds.
Hope this is the information you needed. Good Luck.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 756
1 Opmerking
Give us a bit more info about what you are trying to do? you want to clear some memory? Are you running out of memory?
door oldturkey03
