Why will the bike not start?
this is a 1987 fzr 1000.It won’t start.the starter works and engine spins but it won’t fire up.there is plenty of gas.
Is dit een goede vraag?
I would start by spraying a little bit of starting fluid in the air intake.
Try starting the bike after spraying the starter fluid.
-If the bike starts up and then dies, then you have to check the fuel filter, clean the carburetors, and check for clogged fuel lines
-If the bike cranks over without signs of starting at all then you might have an electrical problem with your ignition system. I would check the coils on the spark plugs and the spark plugs themselves.
Good luck
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 61
Altijd: 1,035
1 Opmerking
Have you checked your spark plugs?
door Broske
