roomba 880 rattling loudly
roomba 880 rattling loudly, on and off, on smooth floor. Can see no initiating factor.
Is dit een goede vraag?
My guess would be that a lot of dust and other debris has gotten stuck around something, which stops the part from spinning smoothly. It may also be that the debris has forced a part away from where it’s supposed to be.
I have another brand of a robot vacuum that I'm taking apart and cleaning now and it really needed cleaning, it didn’t have the same problem as yours but I found a few places where it looked like it would cause a similar problem anytime.
From my understanding, you should be able to turn it upside down by holding the wheels down, I think that’s the mechanism detecting if it’s on the floor or not.
If you feel comfortable with taking it apart and clean it from dust etc., that’s what I would begin with.
If you find what part it is that sounds bad and don’t want to clean the other moving parts when you're on it, you can go for just that one.
I found two guides on how to get to the Cleaning Head and Side Wheels, and this video should also help you.
If you found that a part looks weird/broken in the process of cleaning it, add a picture of it in your question and I or someone else can help you.
Hope this helped, feel free to ask if you wonder anything else and good luck. :D
Handleiding
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Handleiding
Moeilijkheid:
Eenvoudig
4 - 7 minutes
Was dit antwoord nuttig?
The previous advice about thoroughly cleaning is good. My Roomba does have a broken part that causes this though.
I’m not sure the correct name but its the hollow hatch that goes over the rollers. It has broken near the middle on the side away from the hinges. If you get it in the right place before cleaning it works OK still though it can be put out of position if the Roomba goes over something it shouldn’t (a cable or something large).
Maybe worth checking on yours if nothing else helps. Sadly I can’t find a replacement part anywhere.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 60
Altijd: 3,929
So it is not moving and you hear a rattling sound and at the same time the iRobot is turning on and off itself?
door Erik Eriksson
@eke0909
The Roomba moves and vacuums, but it has a rattling noise as it vacuums that goes on and off and is worsening (noise going on and off not vacuum). The rattling is not associated with whether or not the circling brush is active. Sounds as if something is about to fail or fall off.
door s fontaine
@scfonta
So you don't really know what part is moving when you hear the noise?
door Erik Eriksson
@eke0909 exactly. Can't tell and it turns off if you flip it upside down to look. Have done normal maintenance & checked screw on the whirly brush. Was hoping others had had similar issues and could tell me what it is before a part falls off!
door s fontaine
