Ga door naar hoofdinhoud
De C/K, officieel de Chevrolet C/K genoemd, is een serie vrachtwagens geproduceerd door General Motors en op de markt gebracht onder de merknamen Chevrolet en GMC. De C/K-lijn omvat pick-ups, middelzware vrachtwagens en zware vrachtwagens.
Steering column swap 88 to 89
Can the steering column from an 89 be swapped into the 88?
Is dit een goede vraag?
Score 2
2 opmerkingen
This is a K1500 chevy pickup.
door
Yes it is thank you
door
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Gekozen oplossing
Check with a junkyard--they have a manual showing where parts can be used from one vehicle to another.
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
I didn't know that thanks
door
What model will fit a 1996chevytruck steering column
door
But I said 1996
door
By comparing some numbers the 88-94 Chevy 1500 2500 Suburban, 2wd or 4x4 GMC Sierra 1500 2500 will all work. Verified by Hollander Interchange that they do fit. Hope this helps....good luck.
Score 4
7 opmerkingen:
Can anyone tell me what steering columns are compatible with a 1991 GMC C 1500 sierra
door
Hollander huh
door
Ok what years are compatible with a 1991 GMC Sierra
door
Just in case this w help someone.the 1998 gmc sierra steering column is by itself no others fit
door
What steering column will match up with a 1989 Dodge 4/4
door
2 commentaren meer tonen
what other year steering columns will fit in my 95 silverado 1500 automatiac
1 Opmerking:
I'd like to know if a 1997 z71 steering column can be swapped with a 1998 z71 steering column???
door
1990 Chevy suburban 4x4 350 700 r4 tans will a GMC steering column swap work
Will a Steering column off a 1995 Chevy Silverado 1500 fit on a 1995 GMC Sierra 1500 ?? Someone Please Let me know ❗
4 opmerkingen:
yes it will i put one in a 95 gmc i owned swapped right over
door
Would someone please tell me what will swap out with a 1992 chevy steering column
door
88-94 GMC/Chevy full size trucks or vans,Tahoe's/Yukon's!!
door
Can u swap a steering column from a 91 Chevy 1500 automatic with a 92 Chevy 1500 5 speed
door
Voeg je antwoord toe
Steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 30
Altijd: 26,024
