Ga door naar hoofdinhoud
Q7FN 55" Green tint on screen
Hi Guys,
I have this issue with my screen displaying greenish gray from the center of the screen to bottom. I have searched everywhere but cannot find anything about this issue. I have contacted samsung and got the panel replaced 3 times, but the issue persist and exactly at the same spot. It is visible only on gray color especially on 5 - 10% gray level. I cannot see the issue with other color (most probably other color masked the green spot)
What is this issue called? What exactly happen, surely it is not a panel lottery ? as i have got the panel replaced 3 times with the same issue.
Any assistance would be appreciated. Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
The problem may be that the white ribbon cable inside the TV is dirty (oxidation and dust). The fix ... wipe down and clean the connecting points. Clean away any dust, dirt, and oxidation. Consider disconnecting and cleaning any other ribbon cables inside your Q7FN.
Was dit antwoord nuttig?
Almost same problem on my samsung tv
Update (01/22/2023)
Same problem
Voeg je antwoord toe
Weks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,053
