Ga door naar hoofdinhoud
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Vragen Bekijk alle
Is it ok to keep Galaxy S8 365 days a year on charger because HotSpot?
I know it would be better to disconnect daily - but I look answer like - “Samsung officially says DO NOT leave Galaxy S8 for longer than “x” days as it will explode”
I do not look for advise like “ better disconnect it daily” because I need it as HotSpot 365 days a year.
I look for other advises like “open it up - disconnect battery - and S8 will work without it”
But I do not know answer for that question - will it?
I know iPhone not and they will CPU throttle
thank You for help :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Constantly leaving it on the charger can severely damage the battery and cause it to swell up. You could technically connect it to a DC power supply and eliminate the battery but that will look jerry- rigged. Why are you using the phone as a hotspot constantly?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
because it is cheaper to move from WiFi to SIM only (unlimited 4G) here in UK
door
Voeg je antwoord toe
Bart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 32
