Make sure it’s not the adapter. Test it with one you know works and has the same Voltage/Amperage.
If it still doesn’t work, probably the charging port has come loose. It looks sth like this:
https://www.touchfancy.com/product/dc-po...
Make sure its firmly into place. If fixing it/replacing it does not work, then it’s probably a motherboard issue, in which case replacement will come more expensive.
https://www.amazon.com/G9CNK-Dell-Latitu...
I don’t know the excact specs of your laptop, second link is just indicative.
Also, is you warranty still good? Might save you a great deal of time/trouble.
Do any of the led's come on at all?
door mike
yes except the battery light
door imee_sundae
its the adapter, it seems the charger gave up or something.. i dunno.. its out of warranty since i bought it from a warehouse in UAE. Is it safe to buy a docking charger instead of adapter?
door imee_sundae
