Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie voor de Dell Inspiron 15-5559 laptop.
windows update service not found
i have some problem i don't know there are because of the same problem or not?
firstly: the windows update has a problem and i can't update or install from Microsoft store
the message is “Your device is missing important security and quality fixes.
There were some problems installing updates, but we'll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80070424)”
secondly: i don't have the windows update service on services and every-time i run the wuauserv.reg and restart the pc it fails.
thirdly: on the task manager the “svchost.exe” Host Process for Windows Services is running continuously with high CPU and the pc is very very slow
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
There could be any number of problems.
The easiest solution would be to download and run Tweaking.com Windows Repair:
https://www.majorgeeks.com/files/details...
This is a safe site. Have been usings it for over 10years.
Run. Select option to “Reboot To Safe Mode” (bottom, centre of window)
When rebooted run the option to “Check File System” (Step 3:). This checks that all System files are there and not corrupted. Then go on to the Main repair menu and uncheck everything but “16-Repair Windows Update”, 25-Restore Important Windows Services” and 26-Set Windows Services to Default Startup”.
“Start Repairs”
There are other ways of doing all this but this simplifies the process.
Further Instructions
When Windows Update is not working there are generally other more serious operating system problems, even though everything else may seem to be fine to you.
Before "Repairs" do the following:
  • Did you reboot to Safe Mode with Networking?
  • Step 1: (Important) Do a Proper Power Rest First. Click on the "Help" box if not sure how to do it.
  • Step 2: Pre-Scan
  • Step3: Did you run "Check File System" - best done with "Open Check Disk at Next Boot". Did it find an errors?
  • After next "Reboot in Safe Mode" try:
  • Step 4: "System File Check" (this checks for corrupted or missing system files)
ALL these steps are very important if you are getting your repairs are failing.
There are no short cuts to repairs. As the old saying goes "Leave no stone unturned."
In these kinds of repairs it is very important to work slowly and methodically and read carefully everything on the screen, if you want to fix your problem. Each step in Tweaking.com - Windows Repair has the help button. Read them so you have an idea of what you are doing.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
every time i start repairs this message appeared
" Starting Repairs...
Started at (7/23/2020 7:01:10 PM)
Done, but failed, at (7/23/2020 7:01:40 PM)
Total Repair Time: 00:00:32
The current repair has failed to start 5 times.
Something is keeping the repair from running.
Try running the repairs in Windows Safe Mode. (This will keep 3rd party programs from getting in the way of the repairs)
If the repairs still fail then please post in the Tweaking.com forums for support."
door Deel
@Manar Mohammed
I've added more instructions and questions to the answer above.
Just realised I forgot to ask you what version of Windows are you using?
door Deel
@aactech
iam using windows 10.
but now its need to activate
door Deel
@Manar Mohammed
Hi Manar,
Have you done the "Stages" described in "Further Instructions" for Tweaking.com in the revised Answer?
door Deel
I found one effective solution here https://www.repairwin.com/windows-update...
Test if this works for you.
If not, uninstall and reinstall Windows 10 on your desktop to have a try.
step-by-step tutorial; https://www.winxdvd.com/windows-10/free-...
Voeg je antwoord toe
Manar Mohammed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 28
Altijd: 493
