Ga door naar hoofdinhoud
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
334 Vragen Bekijk alle
Replace HDD for HDD Box Buffalo MiniStation 2,5" USB 2.0?
Please do me a favor to guide me how to replace HDD on HDD Box External Buffalo MiniStation (2,5" - USB 2.0). I 'd like to replace the HDD inside that box. This is the link of product, it's quite hard to open (no screws +_+):
http://www.buffalo-technology.com/produc...
Pls help me ASAP. ^^
Thank you so much in advance
I love your site ^^
Is dit een goede vraag?
Score 2
4 opmerkingen
Please, anyone? +_+
door
I need helpppppppp +_+
door
This question was migrated from http://meta.ifixit.com/Answers.
door
I still need your help! +_+
After few weeks, I'm still waiting for a solution! +_+
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
I can find no information on dis-assembly of this unit. Looking at the photo of the unit it appears there is a seam going around it. You might try using a Spudger to go around that seam to see if that gives you access to the drive for replacement. Good luck.
Metal Spudger Set
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Thanks for your answer,
I think so, but actually I'm afraid my outside box will be damaged.
Should I take some photos close up to all of my device's sides and show to you to get an advice?
Have a nice day! ^^
door
You could call the maker and ask for service. Ask them how to open the device. As I said I could find no information on procedures for replacing the drive--I think they may want you to pay them to do it. There is always risk in trying a procedure like opening a case--you have to decide if its worth the risk to you.
door
It has a two year warranty.
Score 3
I made a guide for this, hope it helps.
Disassembling Buffalo MiniStation External Hard Drive (Thunderbolt & USB 3)
Score 1
Thanks guys, Actually, I bought this device in Korea and there is no official reseller or global warranty in Vietnam for it! +_+ So, I will leave this topic open and welcome all the ideas coming before I break it up! ^^
just put an ATM card inside the edge, then lift it up slowly, starting from the long edge!
Voeg je antwoord toe
quangtrungdesigner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 5,501
