Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De 2009-2014 Ford F-150 werd geïntroduceerd voor het modeljaar 2009 als een update van het Ford full-size truckplatform.
Radiator Fans Stuck On High
I have a 2014 F150 4x4 with a 5.0 v8 and it’s just now turned over the 160k mile mark. About three months ago the fans seemed really loud but I’ve not given it any extra thought until now. These babies are working on my nerves! I’ve tried coolant flush and refill and I’ve tried the AC pressure switch. Neither fixed the issue so I’m assuming since the fans only respond to engine temp, trans temp, and AC pressure and both tranny and engine temp is good, I should have my AC system flushed and gassed up with new fluids right? If I’m wrong then I’d like some advice please and thank you!!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
I assume the fans are electric? If that's the case I would check the fan relay. DON'T DO ANYTHING WITH THE AC FREON R134A. You don't need to touch that system. The ac system is a sealed system and doesn't need service. The only thing that should be checked on the ac system is to make sure the condenser is clear and clean and has good airflow and check the ac compressor belt. The cooling fans have at least 2 speeds. It could be a stuck relay.i would get a electric schematic and trace the circuit and find the issue. Also does it have a manual fan? If so it may have a bad fan clutch and a bad fan clutch can have two issues. First it won't spin and cause it to overheat. Second the fan clutch and freeze and it will sound like a airplane under your hood.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I had the same issue. Started after the water pump was changed. The tech put in an after market coolant thermostat. Eventually I took it to a Ford dealer, they went through their overheating diagnostics and narrowed it done to the thermostat. Put in an OEM thermostat and the problem was solved. I recommend going to Ford and let them do the diagnostics since i could be one of many issues. Hope you get it solved. I agree, very annoying.
door Deel
I had this problem. At the back of the boock on passnger side is a small temp censor, which goes in to the coolant stream. I had to get someone more flexible than me to replace it. Must be a common problem, as Auto Zone had a shelf full of them.Costs around $20.
Voeg je antwoord toe
Calhoun Construction Inc. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 72
Altijd: 14,545
