Ga door naar hoofdinhoud
De Samsung Galaxy S6 Edge+ is de grotere variant van de Galaxy S6 Edge-smartphone. Laadprobleem
Why wont it turn on?
my samsung hasnt been able to turn on when i left it charging and woke up in the morning. I have tried everything such as holding the 3 buttons and nothing has happened. it would only stay on 0% battery icon and do nothing, i have booted in recovery mode then it would shut off instantly and go on 0% again. then after it went tonot turning on at all. i replcaed battery and left it charging and nothing too.
Is dit een goede vraag?
1 Opmerking:
Does the charging icon appear though?
If not, maybe it's the charging port.
I am assuming you checked your charger already.
door
Voeg een opmerking toe
1 Antwoord
Try using a wireless charger to see what’s up. If it charges just fine, try using the cable. If it doesn’t take a charge on the cable, it’s most likely the charge port, which is a common failure on devices with MicroUSB. The bad news is if it is the charge port that’s bad, you’ll need to replace the screen as well because the two buttons on the side of the home button are part of the port assembly and go under the screen. Unless you can find someone who’s good at microsoldering they can replace it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Mike Hawk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 340
