Ga door naar hoofdinhoud
Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
Ipad 2 screen problem
Ipad appears to power up and sirrus answers and responds, When powers up, screen appears to be a fuzzy white screen and in center and a black or gray border slowly appears and very fine hortizonal line appears. Only thing i can do is turn off and on. Is this a digitizer problem or is the ipad stuck on this sreen?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi, Robertson.
The iPad 2 is notorious for display issues, and a lot of the time the solution is to smack it on the back like you would when trying to burp a baby. I don’t believe this to be any type of problem with the digitiser, so a replacement of the glass would not help.
if smacking the back of the iPad doesn’t help, you could also try and remove the front glass and ensure the LCD cable is fully connected into the logic board (search for an iPad 2 screen replacement guide to learn how to disconnect and reconnect the LCD cable).
if all else fails, you could purchase a replacement LCD panel and install that. Being the iPad 2 is an old tablet, replacement parts aren’t too expensive.
Again, if you need to replace the LCD, follow the guide on this site for the best instructions on how to do so.
James.
Was dit antwoord nuttig?
Voeg je antwoord toe
robertson5347 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 271
