Ga door naar hoofdinhoud
How come there is an X where the battery is?
I replaced my battery in my MacBook Air 2015. It turned on and there is now an x in the battery icon on my laptop. It also says with my WiFi no hardware connected. How do I fix this? Thanks
Is dit een goede vraag?
1 Opmerking:
Lets get a better idea on whats happening with the battery. Install this gem of an App! CoconutBattery with your MAgSafe charger plugged in take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
Your WiFi issue is a bit more involved as we just not know if the AirPort board has failed or if the antenna has become disconnected or something worse!
Lets open up the system and inspect the logic board and the Airport board. Review this guide MacBook Air 13" Early 2015 AirPort/Bluetooth Card Replacement Do you see any corrosion or other damage? If you do post some pics so we can see whats needed.
Was dit antwoord nuttig?
Voeg je antwoord toe
aimee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 51
