Ga door naar hoofdinhoud
Guides and repair information for VTech landline phones.
48 Vragen Bekijk alle
Power surge fried old base, pairing issues with new base: VTech LS6405
A thunderstorm blew the base to my cordless phone system. I’m convinced that the surge came through the telephone line as the VTech base was the only device to sustain damage even though there were other devices plugged into the same surge suppressor. I’ve purchased a new base set (they come with three handsets), and I’ve replaced the old surge suppressor with one that has a telephone In/Out to prevent something like this from happening again, but I’m having trouble figuring out how to pair my old handsets to the new base.
I always save my User Manuals, so I read through them for both the base and the accessory handsets. Nothing in those manuals addresses how to deregister a handset from a base without using the base. Using the old base is NOT an option as it’s completely nonfunctional in its current state. In addition, because the old base is completely fried, all of the old handsets are displaying an “Out Of Range Or No Pwr At Base” error message. No matter what button I press, I cannot get past this message into the handset menu.
If anyone has any suggestions on how to fix this I’d be super grateful. I really do not want to spend an additional $150 on new handsets over a pairing issue when the old ones work perfectly fine.
A side note: I’m actually pretty good with computer repairs and building/tearing apart a laptop or PC, and I just ordered the parts to repair the Lightning port and replace the battery in my iPhone and feel confident that I’m capable of doing that, but when it comes to repairing other electrical devices, my knowledge is pretty limited (for example, I have zero experience with soldering). I tried to see if I could find where the damage in the old base was but I couldn’t figure it out myself. That being said, I’m willing to learn if someone thinks they can walk me through how and where to look for the problem
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi,
Try de-registering the handsets and then re-registering them to the new base station
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you for your comment!
Under normal circumstances, that would work perfectly - except my old base no longer functions. As I said above, it got fried during a thunderstorm even though it was plugged into a surge suppressor (I think the power surge came through the telephone line because there were other devices plugged into that same power strip and the base is the only item affected; I replaced the surge protector with a new one that has a tel/modem In/Out so hopefully that’ll never happen again).
I still have the copies of my user manual for the original base unit and three handsets, and my additional 5 handsets, and nothing in those manuals addresses how to deregister a handset without using the base. The existing handsets display the “Out Of Range OR No Pwr At Base” message no matter which buttons I press. I can’t get into the handset menu.
Do you think that disconnecting the batteries from the handsets for a few days would reset them?
door
Hi,
Did you try de-registering the new base at all, just in case it had any information stored in it and then de-registering the handsets?
You could try removing the batteries and check. To speed up the process remove the batteries and then press the talk button for about 30 seconds. Hopefully this will drain any residual power from the handset. If it is non volatile memory though it probably won't matter if the batteries are removed anyway. You can only try.
door
I have Hand set CS6609. I lost the base they were registered with. This worked for me. https://www.youtube.com/watch?v=NCHSuoOz...
Score 1
2 opmerkingen:
I have a different model of VTech phone, but this worked for me! The YouTube video was perfect. Thank you!
door
I push the menu button and continue to get the error no matter what I do
door
Voeg je antwoord toe
Angel Phelps zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 1,983
