MacBook Pro Built in Trackpad only working when plugged on charge
Hi Guys.
So My 2011 MBP has developed a fault where the trackpad works completely fine when plugged in using the power adapter. As soon as I disconnect the charger, the trackpad becomes very jittery and its practically un-usable!
I have replaced the battery since there was a message saying “Service battery soon“, but its made no difference.
Ive read on other forums where people have the reverse issue where it works on battery but not when plugged in. Any ideas what the issue could be?
My initial thoughts are some sort of grounding issue? I checked the connector for the battery and cleaned both sides ( Battery + Logic Board connectors ) but still having the same issue.
Can anyone help?
Is dit een goede vraag?
4 opmerkingen
You'll need to see if something pops under the onboard diagnostics. Restart your system and press the D key to enter into diagnostics, let us know what the error messages are.
Reference: Mac startup key combinations
door Dan
The only thing that popped up was "4xxx/6x40000005 <>oa" Battery
I presume this is due to the replacement battery which is not Genuine? The old Battery I replaced was an original Apple Battery that came installed in the MBP
door Ibrahim Hafiji
mmm... Thats telling me the SMC line to the battery is not working.
Lets check the battery and the charging logic, install this gem of an App CoconutBattery with the MagSafe charger plugged in take a snapshot of the apps main window as well as the batteries info tab and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
I have added the images.. Any other info please ask. Cheers
door Ibrahim Hafiji
