Ga door naar hoofdinhoud
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
203 Vragen Bekijk alle
Sound No Video. Half works if one ribbon from T con removed.
I have Samsung 50" LED TV that goes dark if both ribbon cable coming out of the T-con board is connected, but half side works (with white the other side) if I remove one of the ribbon cable. I’ve tried replacing T-con board and mother board. Nothing wrong with cable (I can switch cables and same result). Does this mean the panel is bad on one side? why does the whole screen go dark when I connect the bad side? Any input is appreciated.
Is dit een goede vraag?
1 Opmerking:
what if your model tv doesn’t have a separate icon board where would it be located then. I have a Samsung 40h5003af tv and it had picture that I could see using a flashlight so I changed the lens and now I have no picture. I changed the power supply board and the main board already
door
Voeg een opmerking toe
1 Antwoord
Hi @bumm ,
Try shining a torch at an angle close to the screen on the side where there is no display and check if you can detect any images when the TV is on.
If you can just to eliminate whether or not it is a problem associated with the backlighting i.e. power board or LED strips try the following:
Turn off the TV if on and then disconnect the power from the TV.
Remove the back cover from the TV and disconnect the cable between the mainboard and the power board.
Reconnect the power to the TV.
All the LED backlights should turn on full and stay on. They should all be of the same intensity. There will be no picture as the mainboard is disconnected.
If one side is darker it may be a power board problem or a LED strip problem.
Hopefully a start.
Was dit antwoord nuttig?
Voeg je antwoord toe
Rob Pak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,877
