Ga door naar hoofdinhoud
Uitgebracht in november 2016, beschikt de PS4 Pro over verbeterde hardware voor 4K-gaming en betere PSVR-prestaties.
Help finding HDMI SMD capacitor values
I recently took in a WLOD PS4 pro and was attempting my first ever HDMI IC chip replacement. I successfully removed the chip, but accidentally nudged these two (what I think are) SMD capacitors off the board and lost them. Does anyone know what size or better yet where I can find these components?
The motherboard model is an NVG-004.
It was suggested I try taking components from a PS4 slim, but the slim model’s components are larger than these, and I have yet to get access to a junk PS4 pro board.
Any help would be greatly appreciated!
Afbeelding
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
i measure both of them the big one is around 5.3μf and the small around 100nf
is just bypass caps for the power supply of the hdmi amp, it will be fine if you place not exactly the same values.
like one five micro farads and one three hundred nano farads …
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks man! I’ve been sitting on this board for a while; totally stumped on what to do with it next. I’ll try some different caps from a donor board and see where that gets me.
door
Mario, just wanted to let you know you've helped another person who stupidly undertook trying to fix an hdmi port and had the same issue. Very, very much appreciated!!!
door
I will get back to you later today as I have a PS4 Pro board sitting on my table.
Score 2
Hi,
Can you estimate the size of the capacitors? So I guess the big 1206 and the small 0603
Best Regards
Christoph
1 Opmerking:
I spend hours searching a pcb at my lab... well, no! the big one is 0603 and the small 0201. so you need microscope or magnifying lens. solder the small first i suggest with a bevel tip this board have a lot of thermal capacity... if you want to avoid the small you could try to solder a 3.3uf 0603 and a 2.2uf 0603 in parallel at the big ones pads. otherwise it might work without the small one at all but im not sure about how stable it would be...
door
Voeg je antwoord toe
Jon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 41
Altijd: 2,185
