Ga door naar hoofdinhoud
50" Plasma TV by Sanyo released in 2007.
80 Vragen Bekijk alle
Turns on but no picture
The tv turns on with sound but no picture. Has done this for about 3-4 months now it turns on with nothing but the light and turns off almost immediately. If you turn it on over and over it will finally start up. Anyone have any ideas? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
After having had a few questions about your particular model my first thought is that the power supply circuit has failed and you will require to replace the board. Again, it is very hard to diagnose an error based on a few sentences and not being physical present. You can download the repair manual from here. It does have a trouble shooting section and may help you to further diagnose. Good Luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Cory zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 2,382
