Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Series 3 Notebook model NP305V5A is een budgetlaptop die in 2011 door Samsung werd uitgebracht.
Laptop wrong output after screen replacement
I have an old laptop, Samsung (mainboard) type NP 355V4x-A02ID. It got broken screen and took it to a store. They replace the screen and suddenly the keyboard output were messed up, some key produce missmatch output while other were not working. I complain but they said they only tweak with the screen and never tweak the keyboard. Can’t argue much about that because i dont have any knowledge, so i decided to replace the keyboard. Story short, after a new keyboard was installed, the same problem persist. I was sure the problem were not in the software level as it was not working even in the BIOS. An external keyboard work fine.
What would be the problem, and how to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
I have the same problem.
Today i found a youtube video talk about this, they said the problem come frommthe chip of the new lcd and you have to reprogram or insert the new lcd information
I’m looking the way to do that
Hope it helps
Cheers!
Was dit antwoord nuttig?
Voeg je antwoord toe
Mona Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 475
