Ga door naar hoofdinhoud
The Wii Remote is the original, primary controller for the Nintendo Wii game console released November 19, 2006. The model number for the original Wii Remote is RVL- 003.
My Wii Remote is draining the batteries way too fast.
Hi, community of iFixit! So I’ve got a strange problem with one of my Wii Remotes. One of them is draining the battery surprisingly fast (about 10 minutes from full to flat). The weird thing is that the problem is not with the batteries since I’ve tried many different types, but they are still going flat extremely fast in this Wii Remote. If I put in really powerful batteries, I’m probably getting about 20 minutes more of battery life… But still!
I’m not sure if there is some short circuit in the motherboard in the remote or not, but as far as I’ve understood (by Google) the batteries should begin to go flat after around 30 hours of gameplay. Not 10-30 minutes.
The remote is old, yes. But this is still a weird behaviour. Have anyone got any solution or thought of what could cause this short battery life?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If your Nintendo Wii Remote is having battery issues, use this Nintendo Wii Remote Won’t Turn On problem page for possible causes and solutions.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
That did not help at all. The question posed described the problem well. The remote works fine, but battery life is abysmal. The linked page only has solutions for the remote not turning on. Did you read the question before answering?
door
I'm having exactly the same problem, have you found a solution?
door
Hello I fixed this issue with a q-tip with a couple drops of isopropyl alcohol. I rubbed all the battery contacts (even if none is visible) clean which includes inside the little spaces between and air dried the Wiimote for a couple minutes
After I let all the alcohol dry, I used the semi-fresh batteries that I thought the Wiimote drained and they worked again with the amount of life they shouldve had
So, if your Wiimote doesnt respond to batteries or blinks for a few seconds and dies in a minute or a second, this might be the issue and the fix for it
Voeg je antwoord toe
Linus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 86
Altijd: 6,769
