Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
Is dit een goede vraag?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,257
1 Opmerking
Of course the engine turns over, and there's a spark from the coil wire?
door originalmachead
