Replaced MacBook battery, dies immediately after unplugging from power
I replaced my macbook battery because it was dying immediately after unplugging. I used it for awhile with the power cable duct taped to the laptop. Yesterday I finally got around to replacing the battery and it’s doing the exact same thing - dying immediately after unplugging.
Is there anything that can be done before buying another battery and testing my luck again?
Is dit een goede vraag?
When you replaced the battery, did you remember to supply a new battery daughter board cable? These are necessary for the machine to recognize the battery. You can see what the cable looks like in Step 10 of this guide MacBook Pro 15" Touch Bar 2017 Vervanging van de batterij
door Zach
Thanks for your reply! on my first attempt at repair I actually broke the clamp/hinge to the cable that you referred to in step 10. my second attempt yesterday I hot glued the daughter board cable in place. Sounds like you figured it out! I'll look into what a repair of that hinge might require.
door James Kellogg
Sounds good, please keep us posted and let us know if you resolve the issue!
door Zach
