Ga door naar hoofdinhoud
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Vragen Bekijk alle
Function Copper Strips On Digitizer
Hi,
Recently I was repairing an iPad and I had ordered a cheaper digitizer because the oem’s were sold out. Now I noticed that on the original digitizers there is a copperish square around the screen, but on the cheap digitizer, there is not.
Could somebody explain the function of the copper strip around the screen?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The copper color looking borders on the digitizer are there to stop interference with the chassis which can result in decreased touch sensitivity if not present.
I couldn’t really tell the difference between the silver and copper style digitizers they worked pretty much the same. The copper ones I believe are either OEM or close to OEM quality and the glass is generally thicker and less brittle.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for explaining!
door
Voeg je antwoord toe
Pieter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 263
