Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
409 Vragen Bekijk alle
when I press rt, my character moves forwards
When I press/hold the RT button, my character moves forwards which makes it really hard to play games like Overwatch.
I have a black powerA wired xbox one controller with LED’s on the rims, i forgot the actual name, please help
Is dit een goede vraag?
Score 2
1 Opmerking
Same i have the exact same controller (spectre power A) and this also annoying when im playing minecraft have you managed to fix it i need help..?
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Hi!
Open up the controller and clean it from the inside. Also the input board.. I’m not sure how it looks like inside the PowerA controller, and I think it will be difficult to find replacement parts for that one too..
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thanks for the advice, but ive never really opened up a controller i will try though
Do i have to turn it off?
door
Your welcome! Yes, the controller needs to be turned off. The controller needs to be unplugged.
door
So all I need to do is open the controller and clean it? What parts should i clean, all of it?
door
Yes. Check for dust and remove it. The parts you should clean: Thumbsticks, input board (or ribbon circuit board).
door
what do i clean it with
i have exactly the same controller and the same issue :(
These controllars can be a breeze to clean. You can find how-to-videos on YOUTUBE on how to clean or repair your model of controller. With a Power A You just need a precision screwdriver set, a bottle of isopropyl alcohol (aka Rubbing Alcohol), and some electronic cleaning swabs. And something to organize your screws. Some rubber mats are used for circuit boards and other assorted electronics and have little places to organize and keep your screws in place.
Voeg je antwoord toe
H C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 78
Altijd: 6,587
