Power button solution (DIY desktop)
I am converting my Acer E5 473 into a DIY desktop so I will do not need the integrated keyboard as I can switch it on by connecting last 2 pin (27-28 of keyboard connector) and I am trying to to solder this 2 pin with a push button so whenever I push the button it'll be switched on now my question is there any problem doing so like this? do I need to add any resistor with push button? or I can just go like this?
Is dit een goede vraag?
Hi CalendarMan
Use the multimeter to measure the two keyboard connector.
what values do you get?
Normally it would be just fine as I know Apple also have this kind of power switch device on the switch keyboard.
Hold on and hopefully get some confirmation from the folks here.
door Augustine
@salmonjapan Thanks Augutine for your answer. Currently I do not have multimeter and my question was do I need to add any resistor with that push button?
door CalendarMan
