Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
DC-in board is passing higher voltage than it should - not charging?
The machine was not charging - charger LED remains black when connected to the machine (tried multiple known good chargers).
Reset SMC, no change. Disconnected battery and connected a known good battery with some charge. Was able to power on and see battery stats, showed not charging with power adapter connected. Still no LED light on connected chargers, no charge being transmitted.
Replaced MagSafe DC-in board with two other DC-in boards, same issue with both.
Tested the voltage going through the DC-in board and it gives 19.5 V which is higher than the standard 16.5 V for the MacBook Pro (13-inch, Mid 2012).
Could this higher voltage be due to an issue with the logic board?
Note that the logic board appears to be clean (no clear signs of corrosion or damage).
Thank you for your help!
The following image shows the read-out from coconutBattery with a new battery installed and a power adapter connected to the MagSafe board.
Is dit een goede vraag?
Score 1
2 opmerkingen
Hopefully your system is still running, please install this gem of an app CoconutBattery take a snapshot of the apps window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
@danj Thanks. Added the screenshot to the question.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
OK at this point we know the battery is talking to the logic boards SMC services as the battery info is visible. As you have already replaced the DC-In board and tried a second charger that only leaves one thing left the logic boards one wire connector connection to SMC is not working properly.
At this point you need to get deep into the logic boards logic using a schematics and boardview drawings using a DVM to check the pathways. This really needs someone with deeper skills and access to the needed parts.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Zach zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 100
