Ga door naar hoofdinhoud
Verschenen op 26 oktober 2018. Modellen A1984, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128 of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Wordt uitgesproken als "iPhone 10 R".)
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
door
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
door
Voeg je antwoord toe
s_joseph_ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 6,119
