Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Dell Latitude E5530 is een draagbare computer die op Windows 7 Pro 64-bit draait en ook over een duurzame batterij beschikt. Met een gewicht van maar liefst 2,3 kg (5 pond), heeft deze notebook een dual-core i5-processor, 4 GB RAM en een zeer comfortabel toetsenbord en trackpad.
Computer running too slow
I have a latitude e5530 running Windows 7 Pro with Intel Core i5, and it runs very slow. I start up the task manager, it only uses about 8% of the CPU on average. There is also something wrong with the speakers, there is usually either no noise or it is very faint. I put the volume to 100% and nothing changed. Is there a way to fix these problems?
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Gekozen oplossing
Upgrade hard drive to SSD. This will improve performance.
Upgrading to Windows 10 would also spped it up. It is still a free update with legit W7, as far as I know.
I would especially think this with Task Manager showing only 8%. The old hard could possibly be ready to die.
What temperatures are CPU, etc.?
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
How would I be able to see the details you ask for? I can't find the CPU temp in the Task Manager
door Deel
Do you know how to get to hardware monitor? it is a free software that can check temp, and other things etc.
door Deel
What's their site?
door Deel
@sjhralbert
Sorry have been doing TAXES for last few days.
https://www.cpuid.com/softwares/hwmonito...
door Deel
door Deel
Try cleaning the speaker. It helps with the noise. Take the speaker out of the computer, and brush off anything.
3 opmerkingen:
Well, since this is a 11-year-old model, you have to take off the motherboard and all to see the speaker itself.
door Deel
And what about the slowness problem?
door Deel
No, for the speaker. I forgot that it...
door Deel
All Dells have a Service Tag (like a serial number) on them. For that model, it will be on a sticker on the bottom, possibly under the battery. If you can find it, write it down.
Then, go to Dell’s, website here: https://www.dell.com/support/home/en-us/...
If found the Service Tag I mentioned, type it into the Dell website. This will give you all the system’s details, including how it was configured when it was originally built.
Regardless, all of the Dell software mentioned above can also be found on the same website, two tabs over. Or here: https://www.dell.com/support/home/en-us/...
Finally, this is everything you’ll likely need to dial that Dell back in (also on Dell’s website) https://www.dell.com/support/article/en-...
HTH
To fix the fan problem try cleaning the fan and shooting some air at the whole thing and for the speakers try looking where the connect cause they could be loose
1 Opmerking:
The whole thing meaning the whole computer
door Deel
I fixed the speaker problem, apparently there was something wrong with my headphones. I used another set of headphones and the audio sounded as crisp as it used to.
Voeg je antwoord toe
Albert Einstein zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 32
Altijd: 1,351
