Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to replace my Rear panel?
Hi everybody,
So I have some probleme with button on my iphone (random vibrate due to silence button damaged and power button not working anymore)
I friend just gave me the rear panel from his old iPhone.
I just have a question, at what must I pay attention to prevent any damage to my iPhone?
I readed the guide too
Does someone damaged his iPhone by doing this?
Thanks
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
if you are careful and considerate then it shouldn't be a problem. If something doesn't fit, don't force it, make sure you can see what it is you are pushing/pulling/installing. Look at the way your motherboard is shaped and where camera/sim tray/headphone jack/dock are.. this will guide you in putting the motherboard in safely. The motherboard needs to be inserted sim tray end first and sits under a little lip near the power button, if it isn't in right there then your sim tray won't go in, and your LCD won't close..just a hint. ***Make sure before you do anything that you work on the phone when it is turned off (or run out of charge)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, I will take care of all you said to me !
door
Voeg je antwoord toe
Saxch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 234
