Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Not restoring iPhone 7 plus
Hello I have an iPhone 7 Plus that recently got a little wet and then it went to boot loop and when I try to restore it turns off during “waiting for iPhone” and won’t turn back on if anyone knows how to get past that that would be great thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If it got wet you need to take the phone completely apart and pull all of the covers on the motherboard and clean the corrosion with a qtip and alcohol. You also need to clean all of the connectors. Use a soft brush. There is a possibility that the screen is damaged and may need to be replaced. That may still not repair it. Water damage can a lot of problems. Of starts working it could work for years or a few days. You may micrsoldering repair done to repair the phone. If you need that I would recommend jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com I hope this helps
Was dit antwoord nuttig?
7 opmerkingen:
Hello I know the water damage repair but I don’t know why it turns off
door
It's water damaged anything can happen. You never know what is corroded or shorted and can come out of nowhere. If it's been wet it may have hidden corrosion and it can get worse causing issues.
door
Alright just cleaned it
door
Do you have a sonic cleaner and use ec cleaner. It really helps getting hidden corrosion off.
door
No I don’t but where do you get one?
door
2 commentaren meer tonen
Voeg je antwoord toe
Noah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 111
