Ga door naar hoofdinhoud
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
20 Vragen Bekijk alle
hard drive only works in media player
So here’s the problem, I’ve got a media player with a 2TB hard drive inside it and I want to start using it as an external hard drive instead but, if I take the hard drive out and connect it to a SATA to USB cable, the hard drive doesn’t even turn on.
I’ve checked it when it’s connected in the media player and it works completely fine, I can look at the files inside and everything.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @will_treds
Let us know what hard drive are you using.
I guess you are using 3.5 Inch HDD.
Do note 3.5 Inch need to have external power supply to supply to the hard disk.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
@salmonjapan Oh I see, I do have a 3.5" HDD. Would it work if I put it in an enclosure?
door
Hi @will_treds
you need to get something like this
http://www.orico.cc/usmobile/product/det...
door
@salmonjapan thanks this really helped
door
@will_treds
You are welcome :)
door
Voeg je antwoord toe
William Tredwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 116
