Ga door naar hoofdinhoud
An i7 gaming laptop released in September 2017. Created to fight heat and keep air flowing with thermal engineering systems.
21 Vragen Bekijk alle
Webcam is not detected in stock camera app, I have the latest drivers
Webcam is not detected in stock camera app, i have the latest drivers. I think my webcam is not connected to motherboard so any guide i can reach to the connector and manually attach it
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Just verifying that you toggled Fn + F8 to see if the camera is being turned on and off?
If the laptop’s display works OK then the camera’s motherboard connection should also be OK as the camera circuit wiring is part of the EDP cable from the display to the motherboard.
It may either be a loose cable connection on the camera module or a faulty camera module.
Here’s the hardware maintenance manual for the laptop.
Go to p.58 to view the necessary pre-requisite steps and then the procedure to remove the web cam.
If it is determined that the camera is faulty, the part number is 5C20N00247.
If you search online using the part number only you will get results for suppliers of the part. Here’s just one supplier. It is only shown to give you an idea of what the part looks like and how much it may cost. There are others that may suit you better.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Aditya Gawali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 155
