Ga door naar hoofdinhoud
1,6 of 1,8 GHz dual-core processor, 2 GB of 4 GB SDRAM, 64 GB of 128 GB SSD
Broken logic board header
Hey all,
I have a MacBook Air that's been refusing to charge and I noticed upon tearing it down that the 6 pin header for the I/O board has been ripped off the logic board, or at least that's what it seems. The header can be picked up to reveal 6 equal length pins soldered to the surface of the logic board. If I push down on the header with moderate pressure it completes the circuit and everything works. What are my options here?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You can use a 60W soldering iron to re-solder the header back to the logic board. Use some good flux and some 60/40 solder wire. It will not be that difficult even if you haven’t had any experience in soldering.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Matthew Veitenheimer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 288
