Ga door naar hoofdinhoud
The Maytag model LDE8604ACE is a gas dryer produced by Maytag.
Why is my dryer dead
Hello,
Last night when I went to put my clothes in the dryer my light on the inside wasn't on. I closed the door and push the buttons to see if it would work and nothing happened. I unplugged the dryer and plugged it back in and nothing. I checked the breaker and it wasn't tripped. So I turned the breaker off for a few seconds then back on, still nothing. Can you please help.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi,
Check if the thermal fuse has operated. (part #10 - motor drive parts diagram)
If the fuse has blown it will have to be replaced.
Be aware that there is always a reason why a fuse may blow e.g. if the hi-limit thermostat is faulty and allows the dryer to get too hot then the thermal fuse will operate to prevent a fire from occurring. I’m not suggesting that there is a problem with the thermostat, just that the thermal fuse is the backstop in case anything goes wrong.
Was dit antwoord nuttig?
Voeg je antwoord toe
sweetbear18488 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 403
