Ga door naar hoofdinhoud
De Magnavox MDV2300 is een dvd-speler met ondersteuning voor progressive scan.
DVD disc don't play
I bought a brand new DVD to play in my old DVD player it started Make a lot of noises n started to skip scenes n freeze, i cleaned the laser and put the the DVD back in player stilk the same result play good all the way to the end of movie n then started skipping n freezing so threw the old player away. Bought a new DVD player n now put the same DVD disc on and starts off with the opening scripts then goes directly to halfway to the movie then goes to 1/4 way to the end then goes to the begining n then back to the end then halfway then goes to end credits it's like all the scenes are jumbled up now I've tried other discs that I played in my old DVD player and those discs play just fine confused why this only DVD does that
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @firehelitacker ,
Not working correctly on two players makes it appear as though the new DVD disc is faulty.
Have you checked the surface of the new disc to ensure that there are no scratches and that it is clean etc, you didn't say?
The 3rd post down (Admin’s 1st post) in this link may be of some help determining if the disc itself may be the problem. See the section in the post starting with “On really crappy DVD recordable media,…..”
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 831
