Ga door naar hoofdinhoud
Taping reball stencil or not
I wanted to get some opinions on taping an integrated circuit to a stencil or not. Are most people using tape and if so what kind is best. I have seen some videos were it seemed they just laid the stencil on the the integrated circuit without taping
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s entirely up to you and also depends on the size of the IC. If you feel that taping an IC to a stencil is what makes you feel comfortable and holds the IC in place, that’s definitely ok. I personally use Kapton tape (heat resistant tape) . I have done both ways a few times and after you get a hang of it, you just kind of become used to it. It is ideal to tape really small chips that have a decent sized ball grid array to the stencil.
Was dit antwoord nuttig?
Voeg je antwoord toe
mikespring1972 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 43
