Which screws does MSI gs63 use?
I want to replace my MSI laptop screws because they are broken.
Is dit een goede vraag?
From what I can find it is M2.5 x 6.5mm, Phillips Head #1 screws.
It sounds like the screws are stripped, so this guide may help you get them unscrewed if you have a hard time doing so.
Hoe verwijder je een doorgedraaide schroef?
Hope this helped! :D
Was dit antwoord nuttig?
Thanks you !! I will try it immediately.
No problem and good luck! :D
hello from france is it okay with Msi GS66 ?
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 5,977
2 opmerkingen
What screws are you wondering about? The ones for the bottom cover?
door Erik Eriksson
Yes, the first ones that you need to remove. @eke0909
door Jiahao Cheng
