320 Gb HDD from Toshiba
iPod Classic (new one) will accept Toshiba 320 Gb HDD?
What about this: http://www.amazon.com/Apple-iPod-classic...
Is dit een goede vraag?
If you are thinking about using the Toshiba MK3233GSG in your ipod, then the answer is no. It will not work because it has SATA interface. The 320GB is a dual-platter one, that means that the interface wont fit and it has different mechanics as well . The HDD for the 160GB iPod is 5mm thick and the 320 GB is 8mm. Hope this makes sense. Good Luck
Was dit antwoord nuttig?
There is a 250GB drive out there with an ZIF - IDE Interface. As far as i remember they tested it in a 5.5G iPod Video and it worked.
Thanks you :)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,358
5 opmerkingen
need more information on the 320GB. What is the drive number? What is the interface....your ipod is a 6th gen classic?
door oldturkey03
Thank you. What about this:http://www.amazon.com/Apple-iPod-classic...
door Ted
If your question is if this one will accept the above drive, then the answer is no. Same problem.
door oldturkey03
Thank you verry much.
door Ted
You are welcome, good Luck
door oldturkey03
