Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
Random iPad Air Screen Locks
I recently replaced the screen/digitizer and battery on my wife’s iPad Air. Everything seems to work normally except the screen will turn off and lock at random times, including while my wife is using it. It has even turned off multiple times in a row (in a matter of seconds). She has to hit the Home button and enter her pin to get back in. It appears to happen more often when the battery is low (below about 30%?). I’ve tried turning off Lock/Unlock and setting Auto-lock to Never with no effect. Any thoughts on what might be causing this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I think it may be an issue with the cable for the power/lock button cable or connector. You’ll have to open it back up to inspect it. Look for tears or folds in the cables or damaged, bent pins on the board or cable itself.
Was dit antwoord nuttig?
Voeg je antwoord toe
Dan Barry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 305
