Ga door naar hoofdinhoud
The Asus MeMO Pad 7 ME170C is a touch screen tablet manufactured by Microsoft and released in August of 2014. It has a screen resolution of 1280 x 800. Identified by model number K017.
10 Vragen Bekijk alle
WiFi stays initializing Tablet Asus Memo Pad 7 (me170c)
My wifi does not start, when I activate it it is initializing, I have reviewed tutorials where they tell me to disconnect the battery but it still does not work for me, I also updated the firmware and nothing, I hope you can help me, thanks
Angel S.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
There may be something wrong with your wifi roeter
Was dit antwoord nuttig?
1 Opmerking:
No, other equipment is connected to my Wifi, the problem is that it does not start or does not turn on the wifi of the tablet,
thanks for you comment
door
Hi @ansorial
Not sure if a firmware update resets everything as usually it maintains settings, data etc.
Try starting the tablet in safe mode and check if the WiFi turns on.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one is the cause
If still no good in safe mode, backup the tablet to a computer and then try a factory data reset and see if this resolves the problem.
If it now works OK restore the tablet with the backup you made earlier and then check again that it still works
If still no good when reset, it may be a hardware problem
Don’t know if this will work but try the WLAN codes to see if there is any response.
Here’s a link to the ifixit Asus MeMO Pad 7 ME170C repair guides which will help you to open the tablet.
I’m assuming that the WLAN/BT IC is hard mounted on the systemboard and is not a separate module attached to the board, so it will be difficult to replace it if it is. Look for the markings on the ICs to help determine which one is the correct IC for the WLAN/BT. You may have to search online using the number printed on the IC to find out what it does.
1 Opmerking:
Hi @jayeff,
Thank you very much for your response and your time.
if I get to load the new firmware and factory reset and it remains the same,
I found a tutorial where it tells me to disconnect the battery, but it did not work,
It seems to me that I will have to change the wifi-bt chip because I do not see that it is a software problem, otherwise I will put a usb wifi with an adapter,
I will keep testing and searching,
Thank you for your comments
regards,
door
Voeg je antwoord toe
ASL zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 132
