Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
In 2012 kondigde Sony Entertainment aan dat het bedrijf een nieuwe versie van zijn Playstation 3-console uit 2006 zou uitbrengen. De nieuwe console heet de Playstation 3 Super Slim en is te herkennen aan het modelnummer CECH-4000. De PlayStation 3 Super Slim (CECH400x) is de derde versie van de PS3-spelconsole die door Sony Computer Entertainment is geproduceerd. Hij werd uitgebracht op 25 oktober 2012.
USB Ports problem (No data transfer)
so i’m trying to install games on my ps3 super slim and it wouldn’t detect my usb thumb drive it’s 16GB ,FAT32 the controllers would charge normally i have tried this usb drive on my pc and my old laptop both running windows 10 it works just fine i can’t seem to find any answers on google.
thanks
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
To be honest I’m not very good with PlayStations, but USB ports actually have a very weird type of behavior when they’re broken. I don’t think that I’ve got any clear solution for this, but I’ve got some tips and tricks that you can try.
Broken USB ports can in fact still charge stuff up such as controllers, although transferring data might be impossible. If your USB stick worked with several computers the problem might just be the USB ports. Do some research and see if they have gotten damaged at any point. If that’s the case, a replacement of them might be necessary.
As I said previously I’m not very good with PlayStations, so the problem might also be the operating system. If it doesn’t support the files you are trying to transfer you will most likely get an error message or not find them at all. However if the PS3 doesn’t detect the USB stick at all, try and hook something else up to it (example: another USB stick) and see if that works.
If that worked I don’t have a solution for your problem. However if that didn’t work you should replace the USB ports and see if that will work. Or you could try resetting your whole system and see if that fixes the problem before buying anything, but doing so will wipe your data! So backup anything you want to keep.
I’m telling you again that I’m not very good with Playstations, but I hope that you will find a solution.
Was dit antwoord nuttig?
In regards to this issue your having, if you are able to connect a controller using the USB ports and it connects without issue then the USB Ports are good and in working order. The PlayStation's OS is setup to only allow music and video playback through a USB drive. any other file types on the drive are not supported by the OS. They did that purposely to elevate game piracy. There is an alternative to allow you to play game backups and homebrew however, use a mod chip to modify the system to allow homebrew and backups. If you have any further questions regarding anything regarding electronics, Contact us on our website at CERLV.com
Voeg je antwoord toe
Mostafa Tarek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 2,191
