Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Vragen Bekijk alle
White screen on iPod
Hello,
Does the fact that the iPod is detected by iTunes indicates that the mainboard is fine ?
I have the same problem and I think my iPod has taken too much heat this summer ... but no liquid that I know of ..
So I plan to try to change the LCD screen but I would'nt like to buy an LCD screen if in fact it's the motherboard -- especially because it's out of stock.
So, since my iPod is recognized by windows and iTunes the question is: can I consider my iPod's motherboard fine ?
Thanks
Eriam
Is dit een goede vraag?
4 opmerkingen
Hey Hi,
I received the display and replaced it and the ipod does not work better -- so could that be the logic board: I guess there's not many other options ...
My problem is there is no logic board in stock -- what's the solution ?
Thanks
Eriam
door
eriam, I do feel bad about having suggested that you get a new display. I am pretty surprised about that since I have not yet come across a working logic board with a bad video processor, but I guess anything is possible. Your device is listed as a iPod Classic, can you give me more info on your iPod so that I at least can help you find a new logic board. Sure you checked your connections etc.? ;-)
door
Hey,
I checked the connections and it works :)
The screen connection is especially delicate to put on imo.
Thanks anyways -- the ipod works fine now.
Eriam
door
Yes it is and glad you got it working. Best of luck to you....
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If your ipod sync properly and has no other issues, your logic board will be okay. I bet it's the heat that destroyed your screen. Relative easy and inexpensive fix.
Was dit antwoord nuttig?
Voeg je antwoord toe
eriam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,331
