Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
What should I do if I got warned Error 23 from itunes?
Help i have iphone 3Gs and now i cant get in in to desktop just till the logo apple view, what should i do?
i asked someone and he told me it is from communication board, and i will get charge about 200 US$, is that expensive??
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
iPhone Hard Reset Procedure
1. Press and hold the home button (the big circle with the square inside below the screen) and the sleep wake button (the button on top of the iPhone to the right) simultaneously.
2. Hold both buttons simultaneously for a few seconds, Ignore the “Slide to power off and keep holding them down until….
3. The iPhone should now shutdown automatically – (fade to black)
4. Turn the iPhone back on by hitting the sleep/wake button.
5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
6. You have completed a hard reset successfully (in theory).
iPhone Soft Reset Procedure
To perform a soft reset, press and hold the iPhone’s Sleep/Wake button and the Home button for several seconds, or until you see the apple logo on the screen.
iPhone/Touch restore procedure
Hold down the circular button with the square below the screen WHILE plugging your iPhone or into your computer. You should get the iTunes icon with an arrow on the screen.
Was dit antwoord nuttig?
1 Opmerking:
its still doesnt work, any idea for this problem dude?? i dunno what i have to do with this iPhone i almost 1 month dont using my iPhone..
door
Het nuttigste antwoord
For what my experience indicates is a hardware problem, usually logic board went bad. try with other logic board if you can get one from a friend's iPhone.
Score 1
I had the same error come up consistently. I took it to my nearest Apple Store, because it is under warranty still. They told me that the error is the result of a hardware problem and replaced the phone.
Is your phone by chance still under warranty? If so, make Apple replace it!
If not, you will most likely need a new logic board (the communication board and the logic board for the A1303 model are combined into one board).
Sorry!
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 13,138
