Ga door naar hoofdinhoud
10.1" tablet released in February 2014, powered by a custom version of Android 4.4 KitKat, and identified by model number: SM-T520NZKAXAR
When my battery is disconnected it gives 3.7
But when I attach it to the mother board it's shows 0 volts …what testing should I do to find the problem just bought my first multi meter so i am still learning , want to fix this for the grandparents to have
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
  1. How old is the device or battery
  2. Without any load it may show 3.7V but with load it may fail.
  3. Connect battery to tablet - close device - start it - does it work for at least few minutes
  4. Do (3) then, connect to charger and the press powerbutton.
  5. Can you see the manufactured date in the battery? If it is more thant 3 years - may be better to get a new battery. Search eBay or aliexpress.
(Do not connect to charger without battery - some devices can brick)
Was dit antwoord nuttig?
3 opmerkingen:
I bought the battery last year
After the original one wasn't holding charge , then eventually stopped working wouldn't turn back on
No charge light
Hasn't worked for a year
door
So the device is the currently dead? It was not working for last 1 year.
Then see here:
https://forum.xda-developers.com/galaxy-...
Hope fully other device owners can help you.
door
Thanks for your help , I will check them out
door
Voeg je antwoord toe
Danielle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 100
